Annoying RSLinx. Am I doing something wrong?
Jul 2007
Kiruna
600
Guys,
Something I've got used to over the years but said I'll finally try and do something about it.
Say I want to download/online to a CLX PLC. I click download point to my PLC and no problems. Now say i want to go online to a different PLC with different different IP RSLinx assumes i'm going to same PLC and bombs out because its no longer on this network.
Any way to solve this? Very annoying if you have a few simple mods to do to multiple controllers.
Communications -> Who Active -> [Browse to the PLC] -> Set Project Path -> Save.
This will save the path to the PLC as a part of the project file.
Next time you open it it will also select that path. If you do this to all of your projects then opening another project should change you to the new path.
Yeah just keep in mind that the newer RSlogix 5 will pop you to the browse window every time for the old 5/25 and other pre NP processors. As if thats not irritating. but its not a bug its a feature...
For some reason, when I do a search (Find in Routines, Text Only) in Logix Designer (v30, v32, or v33), I can press F4 and it will step through...
818
Trying to add a device through CCW, but it keeps requesting a password. There is no password on the device (see attached photo) and I have never...
1,895
Does anyone else have the re-occurring issue where Allen Bradley Tag Upload Download tool keeps trying to locate the install file on their...
1,025
Yesterday I went to upload the current program out of a MLX 1400 (i have the source code/project...at least 10 copies of the same program with...
1,947
I need to get rid of this please help When an alarm happen on the HMI it leads to 3 screen popping up and covering all the screen display area...
4,130
