Studio 5000 Logix Designer Annoying Behavior
PCMusicGuy
May 2013
Houston
44
For some reason, when I do a search (Find in Routines, Text Only) in Logix Designer (v30, v32, or v33), I can press F4 and it will step through the search results.
If I take an extremely similar program, v31 instead, and do the same exact search, F4 will NOT cycle through the search results. Has anyone come across this before? If so, did you ever find a solution?
F3 is a standard Windows key for searching. In Studio 5000 on the main window if the Find field is empty, then pressing F3 will open the Find dialog box. If the Find field has something in it, then pressing F3 will do a Find Next. All very typical of most Windows programs.
If you do a Find and instead of selecting Find Next you instead select Find All, then the Search Results window will open. Pressing F4 will step through the items in that window. From what I see, it works the same in version 28 as it is working in version 33. Those just happened to be the versions I had running.
OG
Does anyone know how to set the background colors of instuction blocks (TON, MOV, etc)?
138
Hey Guys, I am looking for a cr@cked version of Studio 5000 Logix Emulator V28 or Rslogix5000 V21, which will work with my current emulator...
282
Good Evening , I have version 28 of Studio 5000 from a few years ago . If I got a new CompactLogix CPU , what is the lowest version of...
478
I have installed Studio 5000 Professional version V36 a time ago and installed today Logix Emulate V36. I have a exsisting PLC program, but...
738
Hi all, I'm going to start programming a 1756-L73 and I'm still waiting for the full Studio5000 to be able to start at it in earnest. But I...
435
