Anyone here a Serial Guru?
CroCop
Aug 2005
Utah
1,050
I've got a Mark III Flow Meter.
RS485, & I can connect over a USB to RS485 convertor.
I have a RS232 to RS485 convertor, & get no joy from it.
Baud rate is set correctly, wired properly, etc., & I'm scratching my head.
Rule #1 of RS-485 is that no two manufacturers designate Data A and Data B the same, so always try swapping data conductors.
The USB device probably allows the software application to command Transmit and Receive modes directly. The RS-232 / RS-485 converter requires handshaking or timing settings to switch from Transmit to Receive.
Do you have RTS and CTS connected on the RS-232 side, or just Rx, Tx, and GND ?
A standard RS232 Db9 socket supplies a 5Vdc Rail
Your Usb lead may not supply that voltage to the rs5484 converter.
If you have a breakout box you could see exactly what is happening.
I have RTS & CTS connected on the 232 side, & have already tried Data A & Data B swap.
I'm thinking the USB device does something interesting. The Emerson product I'm connecting to requires a Modem connection through the port assigned to it. First time I've ever had to do that with a Serial Port.
I received an email from a student with the following code attached. This is supposed to control a floodgate system, and supposed to be written...
23
792
Hi all, I am experienced with Rockwell by have recently encountered a Bosch PLC. It’s an IndraControls XM21 V14. I installed the software and...
777
Hi there, I need to work on a GE series 5 PLC which need DOS based Logic Master 5, it seems like nowhere I can purchase this software anymore...
955
We run multiple products on our machines, which means we have multiple robot programs that we swap to, due to the points for the robots having to...
1,921
I can't seem to increase torque to the desired level w/o the motor just sitting there shaking itself to death. I can only get 80 foot lbs after...
23
4,859
