Anyone using Stratus FTserver ?
TheWaterboy
May 2006
-27.9679796,153.419016
1,927
I'm virtualizing a water treatment plant. While the IT hardware cycle is 3-5 years, to my mind that's really not practical for this kind of installation. So I'm looking for longer term hardware. Stratus FTServer is the only hardware I'm currently aware of that has a longer lifespan of 8-10 years.
Anyone with any experience with these? Or any alternatives.
The Dell VxRail system that replaced the M3000 and VRTX that a different plant has is so expensive for something that will enter EOL in 3 years. Sure you can buy more support but...
I appreciate candor, If all that works now is a 3-5 year hardware cycle for a plant that is not data driven, feel free to tell me I'm a boomer and get with the times. :)
If your looking for IPCS or Servers with a longer life span , Beckhoff make IPCs with Xenon CPUs. They will support for many years.
We have a Stratus FT on one of our assets and although "Stable" we have had a few anomalies with it that have been put down to "Single Upset Events" by Stratus Support
https://youtu.be/AaZ_RSt0KP8
I'm looking to put 6 server VM's on this machine. SQL, Historian, SCADA etc. and stop using single server hardware for each app.
Do you recall what the anomalies were or did?
I'm running a Stratus (the fully redundant one). It's running two FTView instances and a total of... off the top of my head 8 VMs. The Historian isn't on this server though. It's just Data, HMI, DC and Operator Workstations that we're virtualizing with Thin Manager.
So far works great, although I'd spend a good time planning the network and use of the network ports per VM. The previous incumbent disregarded this and we have all machines connected to the same hardware port. Which is something I need to fix, but haven't had the time just yet to do. :(
They can also be monitored remotely by Stratus for a fee, although I'm not keen on that. The state of the Stratus can be monitored via SNMP. We use Kepware, but if I'd defined the project we'd use Zabbix or something similar instead.
Are you not running the historian on it because it can't or you just chose not to for business reasons?
Is the port choked or you are concerned about a single failure point?
I just went to a training class on FTservers and the new panel mounted servers. Seem like nice hardware, just don't know if my customer is going to shell the big money for them. They have 28 RSView32 PC out in the plant now and they die on a regular basis. Have started using new Win10 PCs running the RSView32 on a VM using VMWare Player.
Basically I would have one FTServer in the Computer room rack for Domain, Thin Manager, SQL, VantagePoint and Historian. Then 3 sets of Their zTC Edge servers for 10 thin clients each. Those would be mounted in 3 key areas of the plant in the PLC panels or in a new panel.
The guy above the previous incumbent wanted OSI PI in the OT side to be accessible to the office staff. Which I agree, since the benefits are great, but it makes it harder to create trends for the operators.
The previous incumbent actually didn't want this configuration, probably wanted two instances (which would be expensive, but nicer to work with).
It's coming to the limit to the point that I had to dial down Veeam to run backups as slow as possible. Again, with 7 or 8 physical ports and the virtual networking abilities of ESXi, it's possible to get it better. It's just that I need more time to be able to do it. :/
Hello PLCs.NET! I'm trying to auto-backup some RSNetworx files. Any idea if it's possible at all? I honestly thought that it was just an...
1,545
We are looking to collect information on our cisco and rockwell assets. The exhaustive list that cyber security is asking for .. serial number...
1,664
Going to a free training class on Tuesday. Just wondering if anyone is using this. Pros? Cons?
2,999
I am doing a bit of research before the next project hits. For what I am finding to looks like you *should* be able to set up a multidrop HART...
3,790
I'm working on my 61131-3 knowledge for some up-coming projects, and there is an automated saw on the list that would probably be the perfect...
3,796
