APS vs RSLogix 500
skywalker309
May 2010
Reynosa
28
Hi guys. Let me explain it's a long story. I have a machine with a SLC 500 fixed controller and I need to make some changes in the logic. I can connect with it using Rslinx, then when I open RSLogix, it starts uploading the application, and it suddenly stop and shows a messages that says, decompiler unknow error. Then a guy in my work told me that it may do that because the program was edited using APS, and that it had a different structure, that I needed the original file first.
So I looked for it, and never found it, looks like every time a backup was made that machine was forgotten. Then I got the APS and I thought problem solve, but no.
Now the problem is that it seems I need an 1747-PIC interface, but we don't have that anymore, we only have the 1747-UIC and I don't know how to get online. I've searching on the Rockwell site but haven't found anything helpful. Thanks
43708 - Upload Utility : Unknown Decompiler Error cannot upload file from SLC 5/01, SLC 5/02, or SLC 500 Fixed Controllers.
Techconnect acce$$ . . .
The usual workaround for this old compiler issue is to use the AI-500 based Upload Utility (Knowledgebase Article 43708).
Since you actually do have APS (I think the last version was 6.0) you could try it too.
I know you can use the 1747-UIC with the AI-500 based Upload Utility. Another Knowledgebase article (67110) describes how to use the RSLinx driver (treat the 1747-UIC like a 1770-KF3/1747-KE) with AI-500 based software.
I have been reading everything I can find on the P_LLS the last 2 days but I am still having trouble understanding how the P_LLS swaps beyond 2...
600
Hello Siemens experts. I am trying to register a GSDML file for an Endress & Hauser's Profinet IO over APL (Profile 4.0) compliant device. TIA...
215
When I started as a controls engineer way back in the ‘80s everyone used all caps when documenting PLS programs and in AutoCAD. This was still...
1,684
Hello everyone, So I need help setting up traps in Studio 5000. Disclaimer I'm an intermediate PLC programmer so I need lots of help and I need to...
2,355
I have started to implement an online check sheet for our machines. I have a button that they push for ok and a button they push for NG on the...
1,666
