Can't register GSDML for APL device in TIA portal, HSP missing perhaps?
AlfredoQuintero
Feb 2015
Yokohama
1,552
Hello Siemens experts. I am trying to register a GSDML file for an Endress & Hauser's Profinet IO over APL (Profile 4.0) compliant device. TIA Portal, both v 15.1 and v 18, do not let me register the device. However, the CODESYS engineering tool can register the device. Moreover, the PI's GSDML Checker flags no syntax error for this GSDML file.
Is it necessary to install some hardware support package (HSP) on the TIA portal in order to be able to register GSDML files for APL devices?
That sounds like an excellent question for Siemens tech support.
APL stuff is new enough that Siemens might not support it yet. At a minimum, they don't have any APL products right now.
Yeah, APL is very new. In fact I am working on a display for a trade show where we want to show this device with an APL switch that I am trying to promote here..
Will try connecting the device with CODESYS, and in parallel see if I get some support from Siemens.
I am attempting to reject a bottle If the label fails. The rejection works fine at normal line speed but at low speed the rejector fires (air...
35
1,150
Hi everyone, I am working on a project that needs to expose the SV (Set Value) of a temperature controller to a SCADA system. SCADA <-...
164
I'm pretty new to PLC's, so forgive me if I use the wrong terminology and whatnot. We have an issue at work where we have a flow meter that is...
293
I would like to copy register N61:131 thru N61:147 into ST252:0 I keep failing What happens is I copy into ST252:0,1, 2 etc. What am i missing...
18
591
Hi guys, I am pretty new when it comes to programming. I am working with CX-Programmer and I am having a problem where I have a sensor on my...
688
