Are Step 7 Hardware diagnostic addresses unique?
uptown47
Feb 2008
Over there, next to those boxes
1,146
Hi there
I've got a module in a project that has started 'faulting' (i.e. the Diagnostic buffer is full of errors from the module and OB82 is being called every time the module faults). The module errors are very short (a few seconds) and then the module reports "module ok" in the diagnostic buffer.
It seems like a spurious issue and I was going to change the module for a spare to see if it cleared. However, looking through the hardware config I noticed that there is also an Ethernet Lean card that is using the same diagnostic addresses as this module (1020 -> 1022 inc).
The hardware for this machine hasn't changed in years and this fault has only started occurring in the last few months so I don't think this is the problem but just wondered if anyone knew whether the diagnostic addresses need to be unique and whether its worth changing them?
Cheers :)
Here's one address for the Lean card...
attachment.php
And here's the other unit...
attachment.php
Looking at this again I'm wondering if that "Port" bit for the diagnostic address is a different thing?
The diagnostic addresses for the CP343 are the addresses on its Profinet system. They are not the same IO network as the Profinet port of the CPU and hence they can be the same address and do not clash.
Hello, I have a Step7 5.5 project with a large number of profinet devices which will be activated/deactivated from time to time. I can use SFC12...
2,902
I am trying to install an FVDO-P or an FVDO-P2 module into my hardware config in Siemens Step 7. That is slot 5 of my module. But...
2,779
I have a Step 7 project that, when I try to go online with the hardware config, it says that the configuration is different from what is currently...
7,057
Hello All, This is my first post here so please be gentle with me!! I have a step 7 414-2 with quite a few remote io including rack mounted...
1,594
Does anyone know how to remove a GSD file from the Hardware Catalog in Step 7? I'm running V 5.4 Thanks in advance.
12,757
