Array Af-20mr-e Plc Help
naveed1705
Mar 2006
Karachi
Any One Who can help to communicate the AF-20MR Plc with PC and advise to start a sample progarm in it.
I have installed the software but it is not connecting with the plc
Actually I am novice in PLC Programing , Help will be highly appriciated.
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
257
I am trying to copy an array of real numbers into a UDT with a real data type element. I have attached a snip below showing my COP instruction...
204
I have an array of 55 REAL values. Is there a way to multiply based on the array location ? I have 55 transfer belts that are equally spaced...
155
Hello everyone, I'm working on a project that involves controlling an array of nozzles within a CNC environment, where the nozzles travel along a...
186
Hi. I'm using a Modbus ProSoft where I basically map data to a big INT array. Example, where GX_I_63HPU is a REAL, MNETC.DATA.WriteData[200] an...
21
437
