Arraydata to trendview WinCC Flexible
userxyz
May 2002
any
2,768
I have a measuring system that measures a record every 2 degrees until 380 degrees. this fills 190 records with actual position and a measured value, 2 columns 2D table. In other words: I have 2 arrays with real values in a DB and I want to show 1 column in a trend view on a Siemens Comfort Panel. When I do such thing I would use many many bargraphs connected to an arrayindex... to create a trend feel... however, I was wondering if x-y trend could be used for this. The thing is, I allready have the values, nothing has to get logged over time to fill in a trend...
Any ideas ?
Thanks,
Kind rerards,
Gerry
Any ideas ?
Thanks,
Kind rerards,
Gerry
When I recall looking into this before, it was possible to do something like that in the regular trend view but not the Function (x vs y, or F(x)) trend. If you use the Trend view, you can set up a "bit triggered" trend.
This will probably only be useful if you want to show the Measured Value column, as it will assume they are taken at equal intervals.
Hello! This is my first post on this forum, so welcome. I'm writing an application on Siemens Comfort Panel (TP1900) through WinCC TIA Portal...
3,693
I have an Rsview application that manages 10 PLCs ea plc controls 3-10 oil and water pumps. we use trendveiw and trendx to chart the water and oil...
1,986
Hello Experts I am working on a project with WinCC Unified v16 PC system and want to create an option on the screen to export logs to the...
36
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
69
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
70
