AS2 PCS7 blocks not execute
kallenilsson
Jul 2011
kalmar
Hello Everyone!
Getting ? offline on AS2 CFC and ! ONLINE in my PCS7 CPU 417-H , removed @charts and compiled again, same result.
Searched for NaN inputs, found none. License S7 F systems are available as well.
Any idea anyone what can cause AS2 CFC blocks to not execute?
Hello Everyone!
Hi Kalle!
I'm blank on the H-system (have made some programming for collegues, but never fighted it), but AS2 is the name of your second CPU, right?
And there are no clues in the compilation log?
Have you checked that the runtime group(s) are set active?
Do you know if the H-system interconnection is OK?
Could you make a snapshot of your ?s and !s, I'm not sure what you see/mean?
Kalle
Hi, I am using AS 2.7. Could anybody told me about AR000-emulator? I am using pp420. After building project and made AR000_TCPIP...
3,104
Does anyone have an example project of the cm ptp ET200 SP HA with 410-5H DCS (PCs7 9.1 SP1) for MODBUS MASTER/SLAVE communication ?
134
Hello, Is there a sequence when installing both TIA Portal and PCS7 in the same PC? First TIA and then PCS7 or viceversa? Thanks in advance.
487
Hello, I'm currently working on a project involving both PCS7 (v9.1 sp2 upd1) and a Panel Comfort system. This necessitates the use of TIA Portal...
807
I'm coming from a background of PLC ladderlogic/rockwell products. I am new to blocks. Can you point me in right right direction? What I would...
1,563
