ASCII Application
dennis8437
Sep 2004
19
I am working on an application that will communicate two values via the serial port (CH0)of a PLC-5/40. These values are HEX and arrive in ASCII strings. I was successful in extracting the desired 4 digit HEX strings but now I need to derive the actual value (integer) from these representation.
Thank you for your consideration
dennis8437
Dennis, there is a String to Integer Function I beleive in RSlogix5.
It is ACI in SLC series logic. I don't have the software handy, but you would extract your STring information to a location, then perform the ACI from that point.
Hope that this helps.
Thank you for your attention SNK, however the ACI will work only if the data in the ASCII string represents decimal data. It seems that the function does't like those funny abc's in the hex data.
Hi Guys and the master Bernie :D I need more advice….I know very little about ASCII transmission via RS-232 I am considering purchasing this...
4,595
D
Dear all, I’m working on an application using a 90-30 series PLC (CPU350) and a PCM 301. I have a desktop PC that will send the PCM module an...
9,330
Drewie
D
I'm stumped by something seemingly simple. I want to move the numerical value of an ASCII style SINT into a REAL tag in Studio 5000. What's the...
62
Hi, We couldn’t find anything specific, so am starting a new thread. I’m trying to migrate a config from a ML1400 to a micro820 & am experiencing...
126
I have an L24ER-QB1B with a 1769-ASCII card in slot number 4. I'm looking to send data to this zebra printer after every completed sequence. I'm a...
482
