ASI safe module
AndEdtec
Apr 2002
Wales
78
having problems addressing a safe slave to '0' them getting the master to accept it.
as regard to addressing safe slaves are they the same as non safe?
Addressing ASi safe is the same as 'normal' ASi except you can't use the extended 'B' addresses.
I don't think address zero is allowed with ASi at all.
One more thing - I think some safe slaves only allow you to readdress 15 times before it sticks.
Hope this helps
Paul
Paul's right. AS-I modules are all shipped with address 0 and need to be changed in order to use them. The only time you can add a module with the 0 address is if a slave fails and the "Auto-address" functionality is available. The master will assign the failed slave's address to the new one, provided it's the same type and only 1 module has failed.
Hi all I have a machine with loads of asi safety switches on and I/O I was looking at the OEM Program and I’m thinking that the asi safe is an...
1,353
Hi, I want to know how to read and write to asi safe slave in Microwin. When the input is activated, in the program the contact begin switching ON...
2,344
Sorry chapz my last post about my problem with a safe module was unclear. To cut the story short, i had a safe slave as part of a system.this...
3,762
Just in the middle of instaling asi safe on a machine using a mitsi fx2n and mitsi asi master. Anyone else used asi safe yet or any opinions on...
2,034
How can I integrate my S7-300 Simatic with the IFM AS-i Master AC1335 and its slave IOs, such as 2411 and Airbox 2041, into Simatic Manager?
120
