Siemens asi safe ET 200sp
stu
Aug 2005
England
784
Hi all
I have a machine with loads of asi safety switches on and I/O
I was looking at the OEM Program and I’m thinking that the asi safe is an add on for Tia portal professional v 15.1 and I will need to purchase the add on ?
Im ask as if I need to change the safety door switch in the future I will need to address the new switches and teach the asi master ( but the Oem has said it automatically gets it node from non volitile memory )but then needs teaching via software or hard wired on teach 1 & teach 2 for 3s ??
I haven’t tried yet just after information,has anyone done this sort of thing on a 1500 and asi ET 2000sp ?
It sounds a easy enough my I’m sure if I know the software way and the hard wired way that’s all bases covered ?
If site wiring conditions allow, I would add any new safety using ET200SP safety cards. Things may have improved but my previous experience with ASi has meant I have avoided it.
Hi all , We have a trouble in CP 343-2 Asi master module having issue . When we replace new module we followed the procedure like below. But...
2,100
Hi, I have a customer who would like to add four of our analogue load cells (0-50mV output range) to their ASI network. The customer I don't...
1,616
Hello. I have a problem with siemens asi , first time with siemens asi but not the first time with asi. I have an Dp/asi F-link and a...
2,038
I have a Siemens CP2433 ASI Master module that is acting strange... The module normally scans 30 slaves, and each slave appears to scan without...
3,668
Just a quick one ; i have a faulty siemens asi safety monitor 3RK1105-1BE04-0CA0 and want to replace it with a spare. i have the cable pack from...
4,525
