Siemens/ASI help
DLMUK
Jun 2013
Southampton
311
I have a customer who would like to add four of our analogue load cells (0-50mV output range) to their ASI network. The customer I don't think supplies the ASI components, another company sets up the controls.
I have never done anything with ASI before, I understand the basics but am after a bit more help.
1) Are ASI components compatible cross manufacturers like RS485? I.e. can I have a Siemens I/O block communicating with a bihl master? Or similar.
2) Looking on TIA portal under the Field Devices there is a whole array of options. What I would like to do ideally is plug my load cells into a PLC to store calibration and other items etc, and then provide an ASI output to a master PLC.
Any help would be great - thanks!
I am not an ASI master, but I know a bit.
Yes.
This is not clearly formulated.
It is not described who is the ASI master, your PLC or the master PLC.
Do you intend to provide an output on the ASI-bus for the master to read as an analog signal. I.e. a 4-20 mA signal. That should be doable. But does not make much sense to go via ASI to achieve that.
Or do you intend to provide a signal that the master can read via an ASI analog input. That is doable, you dont even need a PLC. Any loadcell converter that can output 4-20mA can do that.
Or do you intend to create a data transfer over the ASI bus from one CPU to another CPU ? That is not possible. ASI is not a multi-master bus.
Reading this again, I think you want to find a loadcell module that is an ASI slave.
As far as I know there is no such thing, at least not from Siemens. ASI slave types are relatively few. Mostly digital i/o and analog as Pt100 or 4-20mA.
Hello, Right now im sitting here reading manual after manual from siemens.. This far i have now understod how to setup the AS-i slaves in...
2,003
Hi all I have a machine with loads of asi safety switches on and I/O I was looking at the OEM Program and I’m thinking that the asi safe is an...
1,353
Hi all , We have a trouble in CP 343-2 Asi master module having issue . When we replace new module we followed the procedure like below. But...
2,100
Hello. I have a problem with siemens asi , first time with siemens asi but not the first time with asi. I have an Dp/asi F-link and a...
2,038
I have a Siemens CP2433 ASI Master module that is acting strange... The module normally scans 30 slaves, and each slave appears to scan without...
3,669
