Asi safe modules again
AndEdtec
Apr 2002
Wales
78
Sorry chapz my last post about my problem with a safe module was unclear. To cut the story short, i had a safe slave as part of a system.this slave had to be taken off and made to '0'.
later on i come to use this slave again i have checked that it is '0' with a hand held programmer but the asi master kept spiting it out.
Thought I would post my solution just incase anyone else has this problem. You would think that if it is zero it is ready to use but what I found was because it's last state when part of a system was with its safety cicuit open, when you try to get this module into the master it doesn't work because it's transmitting an error.
If you add a brand new slave then there is no problem but if its used it must be 'closed'.
This is similiar when you teach the code sequences to the monitor in that all inputs must be closed.
But I couldnt get that far.
Ok now though.
Hi all I have a machine with loads of asi safety switches on and I/O I was looking at the OEM Program and I’m thinking that the asi safe is an...
1,351
Hi, I want to know how to read and write to asi safe slave in Microwin. When the input is activated, in the program the contact begin switching ON...
2,343
having problems addressing a safe slave to '0' them getting the master to accept it. as regard to addressing safe slaves are they the same as non...
3,587
Just in the middle of instaling asi safe on a machine using a mitsi fx2n and mitsi asi master. Anyone else used asi safe yet or any opinions on...
2,033
How can I integrate my S7-300 Simatic with the IFM AS-i Master AC1335 and its slave IOs, such as 2411 and Airbox 2041, into Simatic Manager?
120
