Badger
If the criteria is the amount of inputs and outputs, then a PLC with 12 inputs and 8 outputs will be twice as good, if you need to explain why then I do not hold much hope for the people that are setting this question.
hello again
Your employer recently won a contract with a local company called Litfuse. You have been tasked to select and describe a type of programmable controller to suit the following application. You also need to state the benefits and limitations of your chosen PLC.
a. A PLC is required to provide sequential control for a fuse making assembly line. The system has an input power supply voltage of 24v dc, with 6 inputs and 4 outputs all are 24v dc.
what i have to do is is pick a programmable controller that is better than the one they have picked and i have to explain to them why its better than the one they have picked at the moment i have picked this one
http://industrial.omron.co.uk/en/pro...c/default.html
because it has more inputs and outputs but thats all i can see with it any chance you can help me thank you.
Because this is a hazardous fuse-handling operation, pick a "safety-rated" PLC (one that has been tested for failure modes, but still has the low-voltage 24 VDC Inputs and Outputs).The system has an input power supply voltage of 24v dc, with 6 inputs and 4 outputs all are 24v dc.
