ATV930 Programming to Control Logix Ethernet IP
jesusramos
Apr 2017
Kansas
Hi I’m having issues figuring out how to connect a Schneider ATV930 to Control Logix PLC.
Can’t figure out the Connection Parameters, I used the following.
Assembly Instance: Input: 100 Size: 8
Assembly Instance: Output: 101 Size: 8
Assembly Instance: Configuration 6 Size 0
Comm Format: Data-INT
I keep getting Module Fault Code (16#012a) Connection Request Error: Invalid output application path.
Please Help!
Hi I’m having issues figuring out how to connect a Schneider ATV930 to Control Logix PLC. Can’t figure out the Connection Parameters, I used the...
1,193
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
117
Hi all, i am the new controls guy at the plant and i have inherited a pc from the previous controls guy with Siemens tia portal version 16 and 17...
20
897
I need to pull the program off of an old 90-30 so I can convert it to Allen Bradley. This is my first time messing with GE and I don't have the...
84
New to vfds. I put in parameters. IP, but I get ethernet flashing and link solid. What did I do wrong?
480
