Authorization logging
dbozic
Oct 2013
Zagreb
74
Hi all!
I have made a Home screen on multipanel mp377 over winCC Flexible Advanced 2008. On that home screen i have 2 IO fields for user and password input and buttons for logging in and logging out. On that screen I have a textfield which indicates if and which user is logged in. Everything works like a charm and logging out deletes username on the IO field.
My problem is when i try to access protected screen, login dialog pops-up. That dialog gives me the name of the user last logged in. Is it possible to manipulate that dialog to show me blank input fields like i did it on my home screen.
I have made everything thanks to wincc script. I'm curious what would the script for my problem looked like, if it's possible.
Why are you not using the built in user and password facility?
This is usually pretty good
Well I would rather implement this functionality in my home screen. Are you talking about popup window when you try to access secured content as built in facility? Because I haven't found other built in facility.
Yes. You can display the user name/group in text boxes if you prefer that..and have a log on/log off button
Hi, I'm working with a KTP700 Siemens HMI and I've had no problem with buttons with no security. I added security authorization (password request)...
989
Hello, I have a problem with an application made in Promotic. The company that made the application a few years ago set the password to edit, is...
1,156
Hi to all. Somebody knows how activate or authorize ProWorx NXT. I was searching in other forums and I don't find info about this. I already...
1,259
Hi all, I'm trying to work out how to control the visibility of an item based on the current user or user group - or more specifically, whether...
11,061
Is there a standard method for using RFID tags to handle user authentication with FactoryTalk ME? I've currently got several panels using the...
4,654
