User Authentication/Authorization Using RFID tags/cards in FactoryTalk View ME
cschlue
Nov 2013
Davenport
34
Is there a standard method for using RFID tags to handle user authentication with FactoryTalk ME? I've currently got several panels using the standard user/password authentication method that we would like to switch to using the same RFID cards we use with our security system. Is something like this possible? I've also got panels running Factory Talk View ME on windows 7 embedded as well.
While i haven't used one with Factorytalk I have tried several different badge readers connected to HMIs and PLCs for operator authentication.
Currently have been using ones by RFIDeas - https://www.rfideas.com/products/readers
They can come as USB, RS232 or ethernet. they can be configured as Keystroking, non-keystroking or ASCII.
We just have our operators use the same badge that lets them in the building. security exports a database we can use to compare to at the machine level and control user levels.
Str8jCkt, just wanted to reply that using the scanner as a wedge worked just fine on the AB HMI's and I only had to configure a hotkey on the scanners for a login button so it was automatic.
I have a Panelview Plus 7 recording data for a customer, who uses FTP to collect the data. Currently it is setup to allow "anonymous" login for...
2,812
Is there a way, for LDAP to function, not by way of a central server, but through a domain/computer that would process users' authentication on an...
2,664
I cannot go online or download to my SLC-505. I recently purchased another license for RSLogix500, but I don't think this has anything to do with...
4,844
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
161
Hi guys! I'm working in Studio 5000 and have a bunch of armorstarts there (+- 40). I need to set up parameters for each of them, mostly just same...
94
