auto logout in iFix 3.5 SCADA
annette2002
May 2004
Hong Kong
I've a button that requires relogin in order to view the data links by button. My problem here is that when the button is clicked, it askes users to manually logout before letting the users to re-enter the user id and the password for verification.
How can I elminiate the part of manual logout?
ifix autologin
Annette,
Pulled this out of Intellutions knowledge base...
Looks like you should be able to modify the code beneath your button with the example listed below.
I woulda tried it but I am currently working with some old Fix 7 and don't have iFix loaded on my machine.
Good luck, Mike
Description
To execute Login.Exe without having currently logged in user name displayed. The following describes log out the current iFIX user out and allow a new user to login without having to logout the previous iFIX user.
Resolution
Create a new picture in the workspace and insert a pushbutton object (which will be used to run a Visual Basic script to logout the currently logged in user, and then run the login.exe program);
Right click the mouse on the newly inserted pushbutton and select "Edit Script";
Paste the following code between the Private Sub CommandButton1_Click( ) and End Sub
System.FixLogout
Dim RetVal
RetVal = Shell("C:\dynamics\login.exe", 1);
Close VB Editor and switch picture to Run mode to test (Note: the script will log the current user out; and then call the login program to allow a new user to sign on);
Save the picture.
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
600
I have a FactoryTalk SE 9.00 application which monitors and controls a batch application in two rooms. When running at full capacity each room has...
732
Hello, I am facing few problems with my FT VIEW 11 HMI (The PLC is SLC Connected via ethernet driver): 1. Is it possible auto logout to login to...
1,079
Hello, I have developed a Factory Talk View SE application and do not have any users or logins enabled. The system is auto logging out after...
4,374
Ok guys I have worked with the Panelveiw plus, and they have it where you can have the logged in user, logged out after certain set of time after...
964
