auto logout rsview 32 cpr 7
May 2008
west central az
61
is there a way to auotmaticly logout a user on rsview after a period of inactivity? we have a few useres on the system here that have acsess to things others shouldn't have and forget to logout when they are done and leave the point open for who ever to get in on there login id.
thank for teh help
See the following technote. You will need a tech connect account. This utility executes a macro after a period of inactivity.
ID
23830
Logging in another user after a period of inactivity.
The RSView32/SE Idle Detect Control ActiveX control (IdleDetect.ocx) is a utility that allows the RSView32/RSView SE system to execute a command or macro after a period of user inactivity. Typically this control would be used to execute the "Login" command to login another user with restricted access privileges. If the "IdleState" is set to False and there is no user input the control displays a count down of the amount of time (in seconds) remaining until the "IdleState" is true. If the "IdleState" is set to True the control displays the amount of time (in seconds) since the "IdleState" was entered.
is there a way to set users up to auto logout after a set time of no activity? if i missed a prevous post on this sorry i asked it again. all i...
3,519
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
629
I have a FactoryTalk SE 9.00 application which monitors and controls a batch application in two rooms. When running at full capacity each room has...
741
Hello, I am facing few problems with my FT VIEW 11 HMI (The PLC is SLC Connected via ethernet driver): 1. Is it possible auto logout to login to...
1,083
Hello, I have developed a Factory Talk View SE application and do not have any users or logins enabled. The system is auto logging out after...
4,398
