AutoCAD Dashed Box
Tim Ganz
Dec 2010
Dallas, Texas
691
I need help drawing a dashed box in autocad around some controls that are in another panel. I see this done in lots of drawings but I can't figure out how to do it. I have been looking on the internet and on YouTube but have not found t yet.
Can someone help me understand how to do this. Print changes are due in a few days and I am behind. I would really appreciate anyone that could help.
Go to the LineType Control and select a dashed line. If you dont have one loaded you can select "other". That will take you the the LineType Manger. There you can select load and then load a dashed line.
From there you can draw a rectangle that will have a dashed line.
if you are using AutoCad Electrical, type at command line : AELOCATIONBOX
Hi Expert: I have used EPlan at previous job, now in the new job they use AutoCAD Electrical, just finished one training at Udemy, it is not good...
1,158
When I started as a controls engineer way back in the ‘80s everyone used all caps when documenting PLS programs and in AutoCAD. This was still...
1,666
Hi everyone, this is a bit off topic and support has not gotten back with me. I am using Autocad electrical and i need to do some mechanical...
1,465
Is it possible for AutoCad Electrical to generate wire lengths, if e.g. paried with a 3D assembly from Inventor with matching part numbers? This...
2,721
