Autocad Electrical 2008 location code
Mar 2009
jaipur
o_O can anybody help me out with the real concept of "Autocad Electrical 2008 location code".I am using it for a last couple of months but wasnt able to make out what the stuff is,N what for it is used????????
though I have a good piece of writnig from Autodesk user group attached below but still I cant make it out......especially WHAT IS THE PURPOSE OF USING LOCATION CODE WHILE PLACING A COMPONENT IN THE DRAWING
Its been a few years since Promis-e, and the ACADE demo that we decided to buy into, but from what I could tell, location codes would be used to name the location of a device. ie- CC101 or CP5 or "2nd floor electrical room" or "Control Cabinet A" or "Vertical Mill #1". You would have to set a location code on each device in one way or another (by page ?)
This allows you to run reports, and sort/filter them by location. You could make a panel BOM for components in one panel (one floor's electrical room, one machine...) but put multiple panels/rooms/machines in one ACADE project.
Hope this helps.
-John
Hope this helps.
-John
That's how we use it. For example, if you want a to/from wire report within a panel you run the report with that panel as the source and destination.
Run the report with all external locations yields all of the field wiring.
Does anyone know how to import an autocad electrical I/O spreadsheet into an RSLogix 500 project.
2,940
Greetings, I use ACE 2008...Does anyone know how to install express tools with this product? It doesn't appear to be available....If I remember...
3,160
Hi Expert: I have used EPlan at previous job, now in the new job they use AutoCAD Electrical, just finished one training at Udemy, it is not good...
1,163
Hi everyone, this is a bit off topic and support has not gotten back with me. I am using Autocad electrical and i need to do some mechanical...
1,467
