Autocad Electrical Block Editor Problem
Pumba
Nov 2017
OHIO
24
I appologize for this thread being off topic, but i am currently having trouble dealing with my block editor in autocad electrical. My experience with blocks in autocad is pretty minimal. I am dealing with an older print and the original creator decided it was a good idea to put the entire drawing in one block. My first idea was to explode the entire drawing and work with that. But instead he turned the "unexplodable" tab on in the block editor properties. So with that being said, i went to my edit block tab and i am greeted with a question pertaining to wanting to save my progress on the DWG. I click my response and i am immediately taken out of block editor. I am unsure if this is a security clause?
thank you.
I ran into this quite a bit ago. Try copying the block and pasting into another drawing (or new drawing), then you should be able to explode or work on the block itself.
Hi Expert: I have used EPlan at previous job, now in the new job they use AutoCAD Electrical, just finished one training at Udemy, it is not good...
1,158
Hi everyone, this is a bit off topic and support has not gotten back with me. I am using Autocad electrical and i need to do some mechanical...
1,465
Is it possible for AutoCad Electrical to generate wire lengths, if e.g. paried with a 3D assembly from Inventor with matching part numbers? This...
2,718
Everyone, Due to covid-19, I am now laid off with no chance of rehire. all the jobs I am looking at want autocad electrical experience. I used...
3,728
