Automatic adaptation of pg-pc interface S7
Plc_User
Dec 2005
Belgium
317
When in your S7 project you insert besides your S7 CPU also a pg-pc station in Netpro and you link the inserted pg-pc to the bus of the cpu (mpi or profibus) will the pg-pc interface for communication adapt itself to the right settings because the pg-pc station is inserted in Netpro? I am using a cp5512 in my pc. Or do I always have to check the pg-pc interface manualy?
Thanks.
Hello, I need to create an automatic transfer panel that connects to the generator when the mains power is cut. I can draw up to 60kW and draw up...
86
Hello everyone, I'm having trouble solving this one and was hoping someone could help. I have a AB CompactLogix L16ER PLC connected to a AB...
588
Hello everyone, I was hoping someone with a lot of experience with Automatic Device Configuration would chime in with any of your thoughts on this...
1,839
Hello. At my job I get from clients lists of their inputs and outputs (hundreds of them) and what they want the program to do. So I have to type...
1,346
For some reason the PLC (TM221CE16T) saves all Memory Bits and Memory Words automatically so after a cold restart it restores not only %MW0 to...
18
4,816
