ndzied1
snaggletto,
Would you be able to use a few limit switches to do the pecking ? BAsically the first limit switch will make it retract then it will go on to the next limit switch.....and so on until the done limit switch is activated. Also on another note, is your product your going to be drilling going to change (thickness) or is it always going to be the same ?
Or, you could use one switch That picks up different cams on the slide/quill of the drill unit. When you start the cycle, the first pulse referses the dril, then on the next stroke the 2nd pulse reverses the drill, and so on.
Depending on the peck distance it may be hard to get the switches close enough to each other. You can make cams smaller and get them closer together. Also the cams or targets should cost less than the switches.
Also, you may be able to add a speed check to your existing system.
http://www.deschner.com/kinechek.html makes them as well as other companies that can be found on globalspec (search hydraulic speed control). The key will be avioding off center loads on the quill.
