Automatic linear curve??
DBLD99
Oct 2003
USA
230
I have a process which uses a linear curve. I have been using the FGEN block in RS5000 for this, and it works great. The problem is the machine Im controlling changes the curve betweek Summer and Winter mode. So the curve is off by a little bit depending on the time of year. Just wondering if someone has a better solution for a automatic linear curve.
Thanks for you suggestions.
X axis = Units
Y axis = 0-100% for the controlling Valve
If you only have two curves (one for summer one for winter), switching between two FGEN will do.
BTW, I like the FGEN, in the most case, if you have enough points and memory, you can get any curves you want...
Already tried switching the two - But I shouldve said it changes more from winter to summer - but also day to day. Its never the same on any two days. PID wont work because it needs to be a really slow process - which I created a RAMP AOI to ramp up to SP really slow.
Hello, I need to create an automatic transfer panel that connects to the generator when the mains power is cut. I can draw up to 60kW and draw up...
94
Hello everyone, I'm having trouble solving this one and was hoping someone could help. I have a AB CompactLogix L16ER PLC connected to a AB...
593
Hello everyone, I was hoping someone with a lot of experience with Automatic Device Configuration would chime in with any of your thoughts on this...
1,844
Hello. At my job I get from clients lists of their inputs and outputs (hundreds of them) and what they want the program to do. So I have to type...
1,351
For some reason the PLC (TM221CE16T) saves all Memory Bits and Memory Words automatically so after a cold restart it restores not only %MW0 to...
18
4,855
