Mildrone said:
Okie, were you considering ordinary cadmium sulfide photo detectors as part of a Wheatstone bridge? Then using the resulting imbalance as a bipolar output?
I never actually have worked on a solar tracking application, it is just one of my re-occurring daydreams.
When I was a 22 year old green tire sorter, I lived in a decent little brick house in Duncan, and about a year after we moved in, the 30 gallon electric water heater cracked. It just seeped, so no damage to the utility room wall.
So when I picked up the new heater, I bought some garden hose to 1/2NPT adapters and about 100' of black garden hose which I installed “in series” with the tank inlet. I ran the hose out the widow right behind the tank, and zig-zagged it across the garage roof, getting east and west exposure on a pretty low angle roof.
It was only up there about three months, but I bet it saved me $50. My wife complained about the smell of rubber at first, but I assured her it would go away and it did after a couple of loads of laundry...my work clothes smelled like rubber anyway.
I never really sealed up the window, and so in the early fall, mice started moving in. So I took it down long before the first freeze. I always wanted to set that up again, with a little PLC and an air purge system for freeze prevention.
The last water heater explosion I had to deal with four years ago resulted in the purchase of a $450 Bosch Aquastar tankless gas water heater. That thing rocked, and knocked $25 off my monthly gas bill at least. Infinite hot water (no savings if you have teenagers). It was cool to open the kitchen faucet hot and watch the burner fire up in proportion to the flow. Tankless is the bomb.
Back on the subject. If the target installation is not too harsh, I would put in a simple HMI. The Red Lion G304, or 306K would be great. They boot fast, so you would only need to apply power to set up the parameters, and adjust the clock. Heck, you could probably put the math in the Red Lion as a program, and only need the operator to input his latitude, longitude, direction, date and time..or whatever parameters make sense.
Is this a portable or fixed application?
Then put in an aiming feature, to let the operator or setup technician to manually jog the thing to perfect alignment, and push a touchscreen button to “calibrate”. In the PLC you just save offsets to your raw data table or recalculate it in the Red Lion if you choose that route.
I would think that on a clear day, perfect aiming would result in a voltage peak from the cells. If you add an HMI, a solar battery voltage meter would be a must have item, especially if your customer is going to be adjusting the vertical (seasonal) by hand. That, with the Jog/Calibrate function would make setting peak efficiency most user friendly.
You might want to use something absolute for position feedback, and of course end of travel limit switches, which could be used as home signals with an encoder. A string pot is an inexpensive absolute feedback device that only requires an analog input.
Just my humble okie opinion.
