Automation Direct CTRIO driving Stepper Indexer
jpn
Apr 2014
United States
Hello all, I have come up against an issue trying to run a stepper motor using an Automation Direct H2-CTRIO2 module. Simply speaking, my setup is an indexing head direct coupled to the stepper. I am indexing to 4 locations and transferring parts to the indexer at 3 locations. I am using an absolute encoder to monitor position, which has not been an issue. I think mostly I am doing something wrong in my logic and I am hoping for a little advice. I have attached my program. The issue that I know I am having is the B2456.0 bit remains RST active after the first scan and I cannot change the logic with my current setup. Additionally, I am using stage programming and I am trying to consolidate my program so I have attempted to jump back and forth between stages to accomplish all of the motion.
Here is a simple description of what I am trying to do.
1. Push button to start
2. Jump to Stepper Stage
3. Move stepper to position 1
4. Jump to load cycle and load
5. Jump to Stepper Stage
6. Move stepper to position 2
7. Jump to load cycle and load
8. Jump to Stepper Stage
9. Move stepper to position 3
10. Jump to load cycle and load
11. Jump to Stepper Stage
12. Move stepper to position 4
13. Jump to load cycle and load
14. Jump to Next Stage in Program
Thanks!
Have an automation direct dl-260 cpu, and the above counting card. Have taken the signal from an existing encoder (1000 ppr) with only one signal...
1,829
I just received a h2-ctrio high speed counter module for a 205 series direct logic Plc with a 240 CPU. Popped it in the last slot (not next to...
3,563
Hello, I have an automation direct d2 262 plc and C-more HMI EA9T6CL-R. I need to prepare a program, scheduled to be performed on a future date. I...
142
Hello all- I have a unique challenge using a customers Direct logic 06 PLC. This customer has a DC motor operating at 10 RPM which is turning a...
147
Hi, I have been trying to run drive via Sysmac studio. I can ping the drive. I can see the logic bits going on/off as per command. But, drive is...
21
588
