Automation using PLC
I would look into home automation for this. I use Z-wave in my home, as well as Zigbee. Take a look at maximum nodes tho.
Use something like this for each socket:
https://www.amazon.com/Enerwave-ZW15RM-PLUS-App-Controlled-Automation-Interchangeable/dp/B07991PBH9
With a controller like this:
https://www.amazon.com/Aeotec-Z-Stick-Z-Wave-create-gateway/dp/B00X0AWA6E
Alternatively, you could use something like this:
https://www.gearbest.com/living-appliances/pp_344666.html?wid=1433363
I use it with one of these as a controller:
https://www.gearbest.com/living-appliances/pp_344667.html?wid=1433363
You could easily pick up the data with 3rd party software, I use home assistant, an open source home automation system.
I have installed OpenHabian over my Pi, and installed Z-way add-on in it too. Cant figure out the way from there..
Hi, I am new here, also I am a beginner in PLC programming and connection. I have a project in which the programming are made for 5 plcs, the...
317
Please friends, I'm researching on 'optimization and automation of cooling tower using PLC'. I need a PLC program to automate the cooling tower...
4,372
My senior project at undergraduation level is “Automation of Parallel operation of generators using PLC”. I am serching any helping article...
2,916
hi everybody, does anybody knows good sites from where i could get information about the PLC based moulding line,the clips wher i could get the...
3,857
I am using Lookout as the HMI and have an Automation Direct 260 plc setup as a master with 250's and 06's as slaves. The slaves are communicating...
10,697
