Automobile: From MES to the Production Lines
userxyz
May 2002
any
2,768
Hello,
For a new plant we are looking for the best way to connect the MES from our main plant to the new plant. The our MES is Simatic IT. Now because the old plant communicates XML between MES and a Master system, we want to replicate this. We do have the choice between a Master PLC and a Master PC. What I see in the old plant is that the Master PLC does not manage where each cabine is, there is only a received buffer that sends data to the first rfid read on the first line. For the new plant I'm thinking to implementent a SCADA layer. The Master PLC in combination with Scada can translate the XML's, place them in a buffer and this way we can do a lot more. So my question...
What are standards about workflow, data management, implement the ISA95 model... Here they are talking about implement the Scada layer (knowing where each product is) in the MES.... to me this sounds odd....
Opinions ?
Thanks,
Kind regards,
G
Hi, We are in a car company. For the PLC, HMI and SCADA programmation we do not have any standards. For the old body we setted up a SCADA system...
2,452
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
121
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
149
I'm a beginner in the automation field and I've set up an automation system connecting several devices (datalogger, radio, etc.) via Modbus RS485...
218
I copied a panel in factory talk HMI for an identical system. The label names are still the same as the original panel but I am trying to change...
142
