Aveva/Wonderware OPC Server works on Admin Account Only
Nov 2018
Michigan
Hello,
I have Aveva 2020 R2 running on a Windows 10 PC. My issue is that the tags on the HMI do not all update (some do) while logged in as Operator account on windows. The SMC log says "Thread ID: 11296. Warning. Gateway. Async Write call to OPC server failed, hresult = 80004004"
Next, I looked into the DCOM settings.
-Ran osconfigurationUtility.exe again. It was last ran on 1/6/2022.
No luck.
Then I checked all these steps were correct:
https://trimaxindo.co.id/wp-content/uploads/2021/02/SP-TN482.pdf
Everything looks ok.
However, for all tags to update I must be logged in as Admin account. I also tried restarting PC and adding new Operator accounts, same result. This is a new one that I haven't seen before Aveva/ updating to new version of WW lol.
Is the target OPC server on the same node as Gateway? It seems like Gateway does not have DCOM permissions to the OPC server.
Gateway runs as SYSTEM by default, so likely this is within the OPC server DCOM. Sounds like maybe the target OPC Server's DCOM Identity is set to run as the Interactive User. If that is so, try changing that server's DCOM identity to run as specific user and use an admin-level account in those credentials. The OPC Server process will need to be restarted to pick up that change. Even better would be if the OPC Server could run as a Service as the SYSTEM user as well, but that's not always an option.
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
209
Hi all, Currently delving into Wonderware/Aveva System Platform for the first time, and I'm trying to set up a script to automatically write to...
979
I consider myself extremely versed with Wonderware InTouch and Archestra, but have not touched 2020 yet. In terms of InTouch scripting, SQL...
2,356
Seems odd that you can make a symbol and place many of them but if the text on a button and or elsewhere in the symbol comes from a Custom...
1,679
I have a problem, I'm running an AE Licence Manager on a Windows 2016 Server, and my Window Maker is on another separate Windows 2016 Server. My...
80
