B&R connection problem
faisal8017
Apr 2014
pakistan
hello
i am using pg2000 on window-XP and trying to go online with CP360 but not succeeded yet :(
i can easily go online with cp360 by automation studio but i dont know why this is happening with the pg2000.
i also run the pg2000 by using DosBox same issue with that. when is press connection button after some time error is display "connection over com1 is not possible, no local connection could be made"o_O
plz guide me to solve this issue.
Hello,
An online connection between the programming software PG2000 and an CP360 is not possible because the DOS based programming software is not supporting the CPU generation (SG4).
PG2000 supports SG3 generation CPUs.
It is necessary to use Automation Studio for the programming.
If you need some further help I would suggest to directly apply to the support of B&R:
http://www.br-automation.com/en/service/support-request/
Hello, I have an MVI56-MNET module, which is installed together with EN2TR, with a subnet of ~10, all instructions have been added to the project...
436
Hi, I bought a Weinview/Weintek MT8071ip HMI and an EasyAccess Activation Card. I have activated the card on the HMI (it says activated), but...
934
Hi all, I really need some advice for establishing communication between 1770 KFD with DeviceNet and my laptop. 1. What cable should I use to...
2,494
Hello there. I have bougth a SMC EX260 SEN-1 ethernet/ip slave and i want to control it from windows PC (with Modbus TCP may be?). Is it possible...
1,002
Having some issues initiating a connection to a S7-1500 PLC over Modbus. I have an OB created with a MB_SERVER block and a configured port (Port...
1,602
