BACNet/Ethernet to AB PLC with RedLion
Cmurph
Jul 2021
Wisconsin
I am trying to get data from a Chiller to an AB PLC or to my SCADA system. The protocol is BACNet/Ethernet, which is a layer2 protocol distinct from BACNet/IP . I am trying to set up my RedLion DA10D to convert the BACNet to something my PLC can interact with. No luck so far.
I attached what I can see with m YABE software.
Hi all, I have a customer who wishes to to display some of the information from their refrigeration plant (CompactLogix PLC on Ethernet/IP) on...
1,521
Good Morning from the "Waist Deep in Snow" Mid Atlantic. I have a question about the 2) options that ProSoft has for Ethernet/IP to BACnet/IP...
4,453
Well i successfully completed the Modbus RTU to Ethernet I/P project and now i have a BACNet MS/TP to Ethernet I/P, CompactLogix project. Trane...
3,689
I am in need of a protocol converter from BACnet to Ethernet IP and vice versa. The Ethernet IP end will be an Omron PLC (probably CJ2M) and the...
9,808
Anyone have success using Ignition 8 and the BACNet driver? We are going to try and read data out of our Carrier Chiller. Carrier tech is...
587
