Bar_code_reading
Manmohan
Jan 2019
Miskolc,Hunagry
Hi Guys,
I am experiencing a problem with Barcode length in compact logix of Allen Bradley. I am using a Keyance automatic scanner SR-750 which is properly configured with the controller and reading the Barcode contents, but the problem is with the length. The length is randomly coming any number (35465 or even more sometime) from the scanner. I do not know how to control the length. Does anyone have an idea about it?
It appears in the IO configuration as a module so-called SR-750. The standard length of the Bar-code is 7 but it can vary if the production department changes the layout and contents of the Bar code. I just want to read the same contents which I see at the time of tuning the scanner and same length. The problem is when I am triggering the scanner from the PLC the received length is too much, however, the barcode contents are being read.
The MSP
I think this is usable when the Barcode length is fixed. What if the Barcode length was changed? I want the bar code reader to read the changed bar code and give me in the programme the changed length.
When the length of the code is variable, the reader is usually configured to add a CR at the end and then in your program you will have to detect the CR character to know where the code ends.
when reading barcodes.
1. what is the format? code 39, 128, 2d, 3d
2. what s the width format?
3. what is the MAXIMUM length?
4. numbers only or alphanumeric?
5. is there a prefix / suffix to the barcode?
when you program barcodes, everyone must agree on these things and then they are set in stone. a plc program reads specific material into its memory based on what you have programmed. once its working, you cannot expect it to read an alphanumeric barcode when you programmed the plc for numbers only. you also cannot expect it to read a 12 digit number when it was programmed for a 10 digit number. if the barcode will change, you must program for the all.
james
Try avoiding a variable length bar code if you can. Easy way around it is have your field length longer (20 characters) and left pad it with zero's. That way you can add more characters to product codes/batch codes or what ever.
A lot of the time the bar code scanning gun handles a lot of that stuff for you
Setting up a Sick Barcode reader to communicate with the serial port of the SLC. Getting the barcode in the following format when I scan...
1,509
How can I do it on ladder logic ? Thanks in advance.
2,429
I have a Keyence BL-1371 Laser barcode reader connected to a Keyence RS232 N-R2 Interface with my Flex-logic PLC Rev 13 Here is whats going on...
3,427
Hey guys, We are wondering what would be involved to have a remote computer populate an excel spreadsheet and a PLC or HMI read these values(via...
1,808
I am attempting to set up a Micro Linx 1500 LRP for comunications with an ascii bar code scanner and need help. I know my way around in regards...
5,253
