Barcode scanner communication with Wago PLC
Mehak
Jul 2021
Lahore
hi guys, I have to write a program to trigger and receive data from a barcode reader via an RS485 module plugged on Wago PFC 200. Does anyone know the way to do it?
Unless ready made code for that specific bar code scanner is available, the only sensible thing at this point is to find the specs of the scanner, more specifically the communication protocol and start from there.
If all you have ever done is turn relays on and off in PLC code, with or without some delays here and there, then you may be in for a bumpy ride. You can learn a lot along the way.
Barcode scanner is of Pepperl + Fuchs manufacturer, Mac address 502, IP is 192.168.1.190, TCP Port (23), Bytes in symbol (13) and output power is 24 v DC. I attached the picture of scanner. I want to communicate this scanner with Wago PLC PFC 200. But the problem is couldn't find any library related to this. If any of you know about this then please help me.
Thank you
Heh, TCP port 23 is telnet, for terminal connection over TCP/IP.
You might be able to run [telnet.exe 192.168.1.190] from cmd.exe to the device and fiddle around to figure out what is expects. Presumably the WAGO has socket-based instructions e.g. CODESYS libraries
  • SysLibSockets.lib
  • SysLibSocketsAsync.lib
Why the RS485 module? The MAC500 you posted has an RS232 port and an ethernet port. Using the ethernet port makes the most sense.
PFC200 can have several PLC runtimes. Wago Codesys V2.3, Wago e!****pit (based on codesys V3.5) or a Codesys runtime.
As V3 was released 15 years ago, you should use either e!****pit or the Codesys runtime. With these I would use the Net Base Services library over syssockets.
Figuring out the telnet commands is a matter of using a manual, or asking P+F if they have a Codesys example code for their sensor.
Hello Everyone, I am looking for communication with delta PLC and barcode scanner over RS485 Please help.. The ladder program will be helpful...
1,869
Brand: motorola Model number: LI 4278 Cradle model number: STB4278 Rs232 cable: CBA-R01-S07PBR To communicate with Plc model: omron CP1E -N30-DR...
2,120
Hello everyone, i want to make the communication between PLC & Barcode scanner. i want to know the steps from starting.Pls help...
4,204
Hi, Kindly let me know, if it is possible to communicate bar code scanner which supports TCP/IP with a 1756-ENBT module.
3,891
Hello, I want to establish the communication between Controllogix plc (2756-L62) to wireless Barcode scanner (MT2090) through prosoft...
5,846
