Barcode Scanner to Panelview Plus
Hank2221
Oct 2011
Tennessee
We are currently using a Panelview Plus 700 to store and load recipes to our plc 5000. We are wanting to incorporate a barcode scanner to take the human error out of the process of choosing the recipe. Our local rockwell supplier is sending us a scanner to connect via USB to the panelview. Of course our recipes are stored in the "recipeplus" but how do I select the correct recipe using the scanner? FWIW we use 26 recipes. Thanks in advance.
Welcome to the Forum, Hank.
Did your A-B supplier provide any documentation that says the barcode scanner will work with PanelView Plus ? PV+ supports "HID" profile devices pretty well (like mice and keyboards) but other drivers are less well supported. The modern PV+ 6.0 operating system has much better USB support, especially for memory devices and printers.
I'm about to get started on a RecipePlus application myself. Are you using the PV+ 5.10 or the new PV+ 6 ? The new one will have a new edition of the RecipePlus ActiveX, which is probably similar in functionality but a little different under the hood to account for the newer OS.
If the barcode scanner works like a keyboard, then it's going to be like a "keyboard wedge", where it enters the barcode data into a Numeric Entry or String Entry object.
If the barcode Scanner works like a serial port, then you're probably going to need to do some work with the Kepware "UCON" driver.
Im trying to select recipes on a PV700 plus using a symbol barcode scanner. We have been doing this by scrolling through the recipeplus selector...
1,740
I need to link a PLC5/30, Panelview Plus 700 and a barcode scanner (currently RS232). My original plan was to use RMTIO between the PLC & PVP...
8,766
I thought I was nearly finished on this TIA Portal/s7-1212C project (famous last words)... Up until now, I'd developed the PLC/HMI such that the...
1,586
I'm wondering if anyone has a solution where I can use a barcode scanner to input a string into a PLC tag. All AB hardware/software. I'm aware...
17,982
Hello Everyone. I am working on a project where I need to scan in 2 Barcodes to populate 2 different tags. A glue Batch and a product serial...
3,108
