Basic DC series question
richleva
Sep 2012
ontario
79
Hello everyone
I'm just getting ready for level 1 electrical exemption exam.
Someone suggested the following awnser to the following problem.
See picture attached. If ground is attached to (+) of the 36V source wouldn't that have adverse affect?
Why do you substract 24v from the 36v?
Please help me understand this ?
The awnser is also showing -12V
Grounding gets a little complicated sometimes. In this case, think of it as a reference point.
Putting a ground between two supplies like that will create some 'positive' voltage (above the ground point) and 'negative' voltage (below the ground point) because you are referencing to ground.
-12V is right for me.
The two batteries in series give 48V therefore each group of 2 resistors has a voltage drop = 24 V, so the difference between point A and ground will be 12V -24V = -12V, and if you calculate it in the other direction it will be 24V - 36V = -12V
Hi Friends, I'm making a PLC operated chocolate vending machine, using a CLICK Basic PLC (C0-00DD2-D) which has 2 x RS232 ports. I'm also using...
1,536
Hi all, I have a noob question regarding data handling from sensors. I understand configurations and I/O mapping sensor input/output variables...
227
Hello I am new here and new to PLC's, I wrote this program for a class that I am taking and my local tech school. The description is switch 7 will...
421
1,991
I’m a bit stuck on HMI (KTP-1200) programming… See the picture attached. The PASS or FAIL box should only appear when the toggle switch is...
1,088
