Basic panel KTP700 / S7-300
Holmux
Oct 2013
Aalborg
279
Hi Everyone
I have a customer that would like me to add a KTP700(PN) panel to an existing S7-300 PLC.
Since this is my first Simatec panel I have been testing it at my desk connected to 1200-PLC, just to get familiar with the setup, the hole thing about programming the panel in TIA and then somehow (and this is where I need help) get this integrated into the project in manager.
Do I need a patch or expansion to get the S7-300 to accept the new panel ?
The 300 PLC might be replaced in a years time, so I guess it makes sense to upgrade the panel, but it is a bit tricky.
Any help would be greatly appreciated đź“š
/Holmux
I had a feeling it would be like that, but don't I have to add a connection to the panel in the 300 PLC ?
I only see the series_1 panels as an option in manager
I use the KTP's with S7-1500's and the plc is not "aware" of the touch panel, the connection is setup in the panel config.
You'll want to add a "device proxy" for the S7-300 in your HMI project, to make it east to grab tags. Otherwise, you need to type in all the addresses manually.
Hi, Im working on adding multilanguage to my project. When using a button to change language I get "invalid value 0 in parameter xxx". The zero...
1,030
Hi all, I need to display an EAN128 barcode on a 7" basic panel from Siemens. The string is in a DB and is 8 characters long (e.g. "40012345"). I...
6,433
Hi everyone, i am working on a project S7 200 plc communication with KTP400 basic PN Panel.i am using a S7 200 plc cpu 224Xp and HMI...
3,939
I have a date time field and have used General Show System Time and date tick boxes in in properties The date format is USA style 12/31/2016 I...
3,225
Hello, last week I had some questons for you about uploading with memory card to a S7-1200. Now I want to do the same for a KTP HMI. I want to...
3,000
