Communication b/w S7 200 plc and KTP400 basic PN panel
SMark
Aug 2016
Montreal
Hi everyone,
i am working on a project S7 200 plc communication with KTP400 basic PN Panel.i am using a S7 200 plc cpu 224Xp and HMI KTP400 basic PN panel and Netlink pro compact Ethernet gateway for PPI/MPI/Profibus. i do not have a ethernet cp 243-1 but i have netlink pro compact ethernet gateway. i want to use RFC 1006 ISO on top of TCP protocol.In s7 300 plc i use this protocol RFC 1006 successfully but i do not know how use of RFC 1006 protocol use in Microwin for s7 200. i hope all expert will help me.thanks
Hello SMark,
Basically netlink is use for ethernet gateway for mpi/ppi/profibus for S5 and S7 plc.it can use as cp 343-1 and cp 243-1.when you connect s7 200 plc and hmi with ethernet protocol.you must have ethernet cp 243-1 or ethernet gateway netlink or other product.so set the parameter of netlink as attach of image.it is possible only when you connect hmi and plc not pc.thanks
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
2,880
can i send and recieve data using my yokogawa UT35A controller with my siemens s7 1200 plc using profinet communication without using gsd file
384
Dear Experts, Good day I have to make ethernet communication between S7-1200 ( 1215c) and Beckhoff PLC CX5010. My question here any expert can...
4,264
Dear Experts, One of my client using S7-300 Plc In that Cp343 Module also using for scada and hmi connection ...
6,836
I’m currently working on a project that requires communication to be established from SIEMENS S7-1200 PLC to the Distributed Control System (DCS)...
7,698
