Basic RSLogix help for a PLC newbie
Barneel
Aug 2013
UK
18
Just learning about PLCs and self-teaching myself RSLogix 500 with a little MicroLogix 1400 controller. I have a basic understanding of the software but like to do things in the most efficient way.
I'm trying to create a basic program that will allow me to make the outputs turn on and off one by one automatically. Each output would, for example, have an LED attached to it.
So as a flow chart it would look like:
Output 0 turns on
Waits 3 seconds
Output 0 turns off
Output 1 turns on
Waits 3 seconds
Output 1 turns off
Output 2 turns on... etc..
I have an idea on how to do this but it doesn't seem very efficient and involves creating a separate TON for each wait. Is there a way I can re-use a TON or something?
What is the most efficient way of making a simple sequence of events like this?
Thanks in advance!
you can use the same timer in series along with step conditions being also made.
--]TIMER.DN[----]STEP=0[-----------------------------------------( L OUT1)--------
---(mov 1 -> STEP)--
--]TIMER.DN[-----] / STEP=0 [-----]STEP=1[------] / STEP=2[---------( L OUT2)-----
-----( U OUT1)-------
---(mov 2 -> STEP)--
hopefully that was clear enough to follow
Another efficient way is to use a SQO sequncer instruction. Here is a 4-rung program that does your routine for 6 lights. You may adjust the S:4/8 bit (from S:4/0 to S:4/15) to get different ON time periods as desired.
If you use Lancie1's suggestion and explore the SQO instruction, you can achieve most efficient by putting the SQO in a STI program file.
The sequence you are describing can be done with 2 instructions, not 2 rungs, just 2 instructions in the PLC !! It is very similar to the age-old "traffic lights" control that nearly all students are asked to program.
No disrespect to Lancie1, by the way, as you did ask for efficiency, his post is perfectly valid in the context.
But be careful when trying to make things most efficient, and especially if you are writing the code for other people to understand/debug/modify.
Most maintenance techs can cope with a few rungs containing XICs, XIOs, and some timers. They may not have the capacity, or the time, to learn and understand the workings of the SQO instruction.
thank Lancie1, this is the best way to do it :)
I would like to find a reference guide, website, book, whatever to help me navigate the concepts of bits in a PLC program. I have been...
1,463
Hello everyone, I am very new to programming, and brand new to Allen Bradley. I am mucking my way through learning the software and things are...
3,413
Hello all, The title explains what I need, how can I setup WinCC V14 and RSLogix Emulate500 so I can read/write values from the HMI to the PLC...
3,009
Hello all, I'm working on a project. It's my first big project working on the RSLogix 5000. I have a long program and different functions. If I...
3,904
Hello, first of all thank you for reading this post. I am pretty new at PLC programming! I have a problem with a CTU and the reset function. You...
5,009
