battery conversion to AC to power boatlift
There are several manufacturers of single-phase inverters offering products for the solar/wind power/off-grid market. Googling with any of those terms as keywords should give you plenty of hits.
As far as power consumption is concerned, if you can figure out how much weight it lifts, how high it raises the weight, and how long it takes to raise it, you can figure the energy and power required. Apply a factor for efficiency of the unit, and you've got a handle on the battery size.
BTW, your link doesn't work.
I have extensive experience with solar/wind power and inverter systems. Give us a few more details, and I can probably steer you in the right direction.
Received via PM
sorry about the post. Don't know what went wrong. It's a geared three-quarter HP electric motor that lifts 4000 lbs about 10'. It's an ACE Boat Lifts 401 power hoist
I'm too electrically dumb to figrue your efficiency calculation, but the single phase remark is very helpful Thanks.
Let's keep it public, John.
The energy conversion doesn't have all that much to do with electricity. It's primarily elementary physics. Raising a 4000 pound load by ten feet requires 40000 Foot-Pounds of energy. That's about 15 watt-hours. That's how much energy storage you need if you want to raise the boat solely from battery power. Unfortunately, that number requires that the energy transfer be 100% efficient, and that you can extract all of the available energy from the battery, neither of which are valid assumptions.
You say it's powered by a 3/4 HP motor. One Horsepower is 550 Foot-pounds per second, so the lift could take as little as 40000 / (0.75 * 550) = 96.97 seconds to raise the full 10 feet at 100% efficiency. In all likelihood, it's geared so that it takes somewhat longer than that.
I'm ashamed to admit this but I've never had to replace a battery in a SLC. Some how been able to skip that task in all my years. So yesterday...
258
Hi to all. On our Siemens PLC power supply, the battery light is showing amber. If we do not immediately change the batteries, will we lose the...
140
Hi there! This is something so old and having machine with it....... Last time unit was powered around 3yr ago and it did not work since than...
241
Customer is buying several spare 504 CPU's to have one handy when there's an issue with the ones in operation. Having them on the shelf for years...
2,839
Our plant has a network repeater station located in a field with two ProSoft RLX2-IHG network radios for connecting our plant network to a well...
2,415
