Battery
natcheappan
May 2010
India
49
Dear Friends,
Am using a s7-400 hot redundancy system.
in the Power supply we are having two batteries.
can you pls tell me if the program inside the RAM will be lost if i switch off the power supply module.
regards
Natcheappan.N
IF
power is switched on OR the batteries are good​
THEN
the program in RAM will remain​
ELSE
the program in RAM will be gone​
ENDIF
Or you can look at it the other way around:
IF
power is switched off AND the batteries are bad​
THEN
ELSE
ENDIF
Kind regards,
I'm ashamed to admit this but I've never had to replace a battery in a SLC. Some how been able to skip that task in all my years. So yesterday...
261
Hi to all. On our Siemens PLC power supply, the battery light is showing amber. If we do not immediately change the batteries, will we lose the...
142
Hi there! This is something so old and having machine with it....... Last time unit was powered around 3yr ago and it did not work since than...
260
Customer is buying several spare 504 CPU's to have one handy when there's an issue with the ones in operation. Having them on the shelf for years...
2,863
Our plant has a network repeater station located in a field with two ProSoft RLX2-IHG network radios for connecting our plant network to a well...
2,440
