Beckhoff CX9000 Stuck in Config Mode
May 2010
Indianapolis
I have a cx9000 that has started up and will not get out of config mode. The power LED is Blue. I have reset to factory defaults, forced it in and out of config mode and nothing seems to get it out of this mode. Since then I have had to replace this particular one with a new module, but am still wanting to get the original back into working order so I can put it into my spare parts. If you know how to get it back to working order please let me know, as my facility runs 250-300 of these modules all the time.
no, all the dip switches are in the down position. i have used dip switch 1 to reset it back to factory defaults, and have also used dip switch 4 to force it in and out of config mode. nothing seems to get it out of this mode though.
How do you do this on a 9020? There are no dip switches?
Has this controller ever been in Run Mode? If it has, there are a few things that can prevent it from going back into run mode such as a corrupt configuration. You will have to reconfigure with System Manager.
Hi, I'm working with Beckhoff CX9001-1001 and CX9000-N031. I want to have 2x RS485 modbus rtu, how N031 must be configured in System Menager...
2,690
Hello, I am trying to open the PLC project directly from the Beckhoff CX9000 (Screenshot 1) to do a backup of the project, because we don't have...
8,028
Heloo, I have problem to communicate with Beckhoff CX9000 PLC and Denon AVR 2313. I want to send commands to Denon receiver from PLC...
3,227
Hi, I have a problem with implementation of Modbus TCP/IP on CX9000. I did install Tc.ModbusSrv.lib in Twincat ( i use Twincat 2.10 v). I'd...
9,812
Hello! I have Beckhoff CX9000 with N031(2 RS-485) module on board and Mitsubishi FRA740 inventor. I need to control inventor with Modbus RTU, but...
4,171
