Beckhoff CX9000 tcp/ip communication problem
Fleeceable
Jan 2013
Antsla
Heloo,
I have problem to communicate with Beckhoff CX9000 PLC and Denon AVR 2313.
I want to send commands to Denon receiver from PLC.
Communication must be over TCP/IP.
Can someone help me to connect these two devices?
I have tried to use Tcpip.lib in Twincat but if i use Socket_connect Function Block then it gives me to error code 6 (target port not found)
Some examples are welcome!
Hi, I have a problem with implementation of Modbus TCP/IP on CX9000. I did install Tc.ModbusSrv.lib in Twincat ( i use Twincat 2.10 v). I'd...
9,816
Hi, I'm working with Beckhoff CX9001-1001 and CX9000-N031. I want to have 2x RS485 modbus rtu, how N031 must be configured in System Menager...
2,694
Hello, I am trying to open the PLC project directly from the Beckhoff CX9000 (Screenshot 1) to do a backup of the project, because we don't have...
8,030
Hello! I have Beckhoff CX9000 with N031(2 RS-485) module on board and Mitsubishi FRA740 inventor. I need to control inventor with Modbus RTU, but...
4,172
I have a cx9000 that has started up and will not get out of config mode. The power LED is Blue. I have reset to factory defaults, forced it in...
5,190
