Beckhoff CX9020 + CP6066 HMI
Luchian
Oct 2016
Bucharest
19
Hi guys,
I have a CX9020 Plc and some modules and I want to connect my PLC to CP6066 which is a HMI from Beckhoff. This HMI uses Twincat 2.11, my CX9020 is programmed with Twincat 3. How can I download my vizualisation to my HMI ? I found some info on Internet, but I couldn't make it work.
Thank you.
Hi guys,
Thank you.
Nobody ?
For starters, you will need both TwinCAT 2 and 3 on your programming PC if you want to work on both these systems; I assume you know that already.
You should be able to communicate between the systems using ADS. Here is an example:
https://www.dmcinfo.com/latest-thin...ing-tags-between-beckhoff-plcs-using-ads-read
Well..I'm not so sure if that is a good solution. I think I found one, but I'm not so sure. I think I shoud use Remote Desktop. I found the applications on both devices. And then I will run Tc3PlcHmiCE. What do you think ? Is it possible ?
#Edit... The HMI is CP6606
At our company we are using Beckhoff a lot of cx9010 en cx9020. On one of the cx9020, after the scan devices is done in the system manager, there...
3,354
I can't for the life of me figure out how to perform a factory reset on a Beckhoff CX9020. There is nothing in the documentation. Help? Bigger...
13,713
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,036
Hello sameone have Beckhoff PLC Siemens Sinamics V90 configuration example?
101
hello, I am using Beckhoff with TwinCAT3 and when I change or add some new hardware or for any reason, there is a mismatch in the real hardware vs...
131
