Beckhoff Devicenet Addressing for Bus Coupler
JerryH
Mar 2009
Tellico Plains,TN
110
Hi all,
I am going to change an existing Beckhoff I/O system that currently is using CanOpen to Devicenet. I've been trying to figure out the layout of the data I will see on devicenet coming from a rack of Beckhoff I/O through a BK5220 Bus Coupler. The analog I/O makes sense, two bytes for each channel. The digital I/O makes no sense to me. They are allocating a bit for each channel of digital.
Taken from their manual:
When the last analog output terminal in the terminal strip has received its
data, the digital outputs are served. Data is always transferred in the form
of bytes, so the next byte from the data string contains data for 8 digital
outputs. Bit 0 and bit 1 are assigned to channels 1 and 2 of the first digital
output terminal after the Bus Coupler. Other types of terminal which are
located in between are ignored.
Bits 2 and 3 go to the 2 channels of the second digital output terminal, bits​
4 and 5 to the third and bits 6 and 7 to the fourth.
Any have any experiance with this and can help me understand?
thanks,
Jerry
No, POS7 means position 7 where is one two channel output card. So First cards (first output cards, there are input cards before that in manual's example) two outputs are 12.0 & 12.1 (byte 12's bits 0 and 1).
POS8 is again two channel output card etc.
Ah, so their definition of a channel is a single point. A 2 channel input card is two points, not 8 or 16 like I was thinking.
That makes some sense now.
Although technically you may be right, I somehow cannot link the word "channel" to a discrete line.
Well, i cannot understand what line has to do with it?
Think about "discrete signal channel" and "analog signal channel" and generally "signal channel" does it not make sense to you?
Hi there, I have a Beckhoff PLC rack with the BK5220 bus coupler, communicating over DeviceNet with Allen Bradley scanner card. I am receiving a...
439
We have an AB SLC 5/03 that's been running since 1999 with a Beckhoff BK5200 connected to it. Just in the last month or so the BK5200 has been...
1,534
I am trying to connect an Omron NSJ with DeviceNet to a Beckhoff I/O system. The Beckhoff I/O has two Bus Couplers BK5220 with I/O cards, two...
4,948
HI FRIENDS I am using beckhoff industrial PC in that i am using Devicenet Module.I want to reset the module during running. Is there any command...
4,674
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,033
