Beckhoff BK5220 AB DeviceNet Fault 77
Bedardoh
Aug 2023
Ontario
Hi there,
I have a Beckhoff PLC rack with the BK5220 bus coupler, communicating over DeviceNet with Allen Bradley scanner card.
I am receiving a “Node 2 - Fault 77” on the AB scanner card.
I am receiving a “Bus Off” Fault on the bus coupler.
The “Bus Off” Fault will blink 4 times then the LEDs on the bus coupler will go back green, then Bus Off will blink again 4 times and it will keep repeating itself.
I am receiving 46/50 bytes on the digital inputs. I have tried to swap out all of my input cards, however, I haven’t had any luck getting 50/50 bytes.
This issue is intermittent. Maybe 1/20 power cycles the PLC will communicate without and faults. As soon as I power cycle again, I lose it, and right back to square one.
Has anyone had this issue or have any reccomendations?
Thanks.
Hi guys It's 6:52AM sunday and people from my company just woke me up cause of some Beckhoff BK5220 DeviceNet issue lol :bow: They are trying to...
3,135
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,026
Hello sameone have Beckhoff PLC Siemens Sinamics V90 configuration example?
101
hello, I am using Beckhoff with TwinCAT3 and when I change or add some new hardware or for any reason, there is a mismatch in the real hardware vs...
130
I have a Beckhoff CX7000 IPC with some digital I/O built-in and I additionally need two analog inputs 0-10V. Can I install both Ethernet terminals...
210
