Beginner: Old DDE-server on windows vista ?
Apr 2010
Randers
I have no PLC experience and very little knowledge of PLC, but my background is a programmer in mainly java.
At my new job, I have an assignment to retrieve live data from a PLC.
The setup is a tropical zoo, where a 'priva' PLC controls the climate inside the zoo. The PLC is conneted to the ethernet network.
I like to retrve live climate data from the PLC. My company have a licens to a DDE-server on an old win98 computer.
The DDE-server can retrive live data from the PLC to an excel-spreadsheet.
The old win98 machine has been in storage for years, but I found the old win98 computer and hooked it up, and the DDE-server export to excel still works on that computer. In theory I could use the old PC, but I would like to work with it on a new computer i.e. Windows vista or windows 7...
If I copy the DDE-server to my windows vista machine and try to start it up, it does start up, but it does not export data to excel. I suspect it is because the DDE server uses outdated windows system-files.
Any idea how to retrieve the PLC data on my Windows vista pc?
Is there a way to just connect to a PLC
Hello, doing switch from FBD to ST. First task is converting my old work. How do you sum variables? For example, Interlock1, interlocl2 and...
216
Hi all, Writng a FB in ST on Beckhoff TC for a pulser which turns on and off on a cycle, is paused by turning bControlInput to FALSE, but resumes...
310
So to start off: I have no experience with PLC's, but I'm good at figuring stuff out, but I need some help to know if my PLC is just dead in the...
160
Dear all, First of all thanks for letting me join this forum. I just need some help in one of my programming exercises. Being a beginner...
640
I am trying to connect to SLC5/03 using an FTDI usb to rs232 with female to female converter at 1 end... however I can not connect to it ... the...
1,321
