r_boxblast
OP
mordred said:I thought we were just controlling 3 outputs?? 200.00 to 200.03?????
if that is the case I've converted Alarics example to syswin
I can help you better if you can give me a truth table(desired conditions at what times) with an accurate I/O list
first i can open the file u uploaded..it says 'This file is not a CPM*/SRM* project. While running in "CPM*/SRM* mode" it is only possible to edit CPM1/CPM2A/SRM1/SRM1-V2 projects.'
Im not sure how the truth table works, so i just explain how i want the outputs to be.
Clockwise
Turn switch 000.00, then output 100.00 for 15 sec
After 15 seconds output change to 100.02 for 15 sec
After 15 seconds output change to 100.04 for 15 sec
After 15 seconds output change to 100.06 for 15 sec
After 10 seconds output change to 100.05 (delay for the motor to stop b4 proceed reversing the direction, any output will do so i just put there 100.05)
After 10 seconds output change to 100.08 (this output will always be activate during the reversing)
Then output 100.00 for 15 sec
After 15 seconds change to output 100.02 for 15 sec
After 15 seconds change to output 100.04 for 15 sec
After 15 seconds change to output 100.06 for 15 sec
Then loop back to start (Clockwise)
hope can change my program a little bit.
